Hi All,
I am new to the DIY side of things (not that this really constitutes that!) I am about to install the NC220 Qudos boards into my Avondale 130Z amps but i have a few queries.
Firstly, when i am desoldering from the signal connection on the NCC200 boards, do i need to remove all solder from the cable and spades on the board ? And when i solder the cable onto the new boards, do i simply tin them first, then solder to the new spade ?
Secondly, when setting the amp bias, i am aware that the NCC220's need 120mA, but do the new boards come with this set already or should i double check anyway ?
On this point, i have a fairly new UNI-T 139C meter and apart from using it for basic 12v battery checks, i have no way of knowing how accurate it is for the mA bias and offset DC. As a guide, i checked the existing bias on the NCC200 boards and they are coming out around 23.8mA, does that sound about right ?
Thirdly, how much thermal paste should i use for the new heatsinks on the Qudos modules ?
I can't wait to get these boards installed but wanted to double check these points first.
Apologies for the daft basic questions but its better to be safe than sorry i figured.
Thanks all
Simon
Thanks all
Simon
