Hi all,
My system is as follows:
Squeezebox Touch > Audiolab 8200DQ > Meridian 557 power amps (balanced)
I also have an Onkyo AV amp hooked up to an analogue input on the Audiolab.
Earlier I decided to install the enhanced audio output patch on the Touch and use the USB connection instead of optical. It worked a treat, but with the USB cable attached between the Audiolab and the Touch, there's a rather prominent high-pitched whine from the speakers when I switch to the analogue input on the Audiolab.
Disconnect the USB cable and it's gone.
I'm back to optical for now!
Any ideas?!
Any ideas?!
