That kind of depends on the asking price. If it’s cheap enough, it might be worth the risk.Realistically, run away, unless you have access to all the build info, and can check part availability. Could quickly become a doorstop.
Depends on what it is and what is wrong with it. There is nothing inherently different about digital kit. One only needs to look to the currently huge retro-computing and gaming market for countless examples of people restoring really ancient digital kit. The problems comes with any bespoke chips, LCD displays etc. I’d say if it was a well documented mainstream item there will be a fairly good chance it can be serviced. Really there is no logical difference between a hi-fi DAC and say an Atari 2600, BBC B or Sega Megadrive when it comes to servicing. Its just components on a board, if you can figure out what is wrong and find the part it can be fixed. Obviously getting hold of the schematics is a huge first step.
Can I jump in and ask in very very non technical terms what is likely to be the problem on an Einstein pre-amp that causes one channel to have less volume than the other . I have already tried two repair outfits but It was beyond their ability to fix the problem.
I know It is the amp-not speakers etc, Thanks.
Simply known as The Preamp 19 small valves, 3 balanced 2 rca, fairly heavy and wooden crate.You haven't tried me yet Which model is it?
Thanks Jim
No circuit diagrams and Einstein are very protective of releasing information because they have been pirated before!
Neither complained, It was beyond them, my words,one well known outfit (Peterboro) claimed to have fixed the problem but did zero and charged a lot.
It is an exceptionally good amp which sell for good money, over £10 new and I hope to repair and sell.
