Big John
I decided to re-lube my Michel Transcriptors Hydraulic Reference TT bearing
After a very patient (him) and helpful exchange of emails with John at Audio Origami I decided to put Audio Origami Booster oil on my Xmas list
The Results.....
Using a digital photo tachometer a Xmas present from my grandson his mum (my daughter) bought the Booster oil.
My Transcriptors Hydraulic Reference is fitted with an Origin Live DC motor The bearing is a 1/4" Silicon Nitride ball on to the original hardened steel thrust plate, with original PTFE bushes around the shaft.
Spin down time with no belt on ie. spun by hand from 34 RPM 1min. 07.3 sec to stop before changing the oil which was Syntrax 75/90 semi synthetic gear oil. There was no discernible rumble.
After the oil change to Audio Origami booster oil from 34RPM to stop 1min 57.6 sec. whilst again no discernible rumble the platter moved more easily, making fitting the belt trickier.
Speed stability of platter when belt driven measured after 4 mins warm up. with no record/stylus drag, before changing the oil 34.7-32.3 RPM over 1 min. After changing the oil to Audio Origami booster oil with 4 min warm up 33.6 RPM no drift over 3 mins measured time. The motor speed control was NOT adjusted
So far brilliant, now after an extended listening period...I have listened to a few records my observations re audio Origami Booster oil are, plucked guitar & double bass, there is more space around notes, violin are less strident in upper frequency's and clearer closer to live performance sound stage seems deeper.
Voices have better separation. siblence is less noticeable the noise floor seems lowered, the dynamic range appears extended
I have spent a lot more money to get this sort of improvement ...
The Results.....
