Just curious at the moment following me reading the recent sub thread (which I didn't want to derail), about whether getting a single subwoofer to use with a pair of small standmounts could be a way to get good sound in a relatively small (~13' square) and awkward room.
I was wondering if there is any general rules about what sort of size subwoofer to look for, and whether there are positions for locating subs which are considered either good or bad? Room layout dictates that there is really only one place a sub could go in the room, with only a little space to play with in that position whish is in the front left corner, to the left hand side of the left speaker. The spot available, measured out from the left side wall is about 50cm wide and could be about 80cm long when measured from the front wall in which to move the sub around.
Re-arranging stuff to make the above mentioned space will be a bit of a faff, and I would rather avoid the faff if it doesn't seem likely a sub in that position would work. Does it sound like it might be doable?
