PigletsDad
My intelligence test came back negative.
I am pretty sure that the cost of a power amp is dominated by the cost of the power supply parts. Designs that use multiple transformers are even more expensive.
For active systems, or I guess home theater, large numbers of power amp channels are needed, and the total cost can be quite high. An active home theater system needs LOTS - 5.1 with 3 way everywhere uses 16 channels!
In this type of case, it is worth thinking through if there are design tricks that can maintain the quality level, while allowing a shared supply to run many channels.
A design with high PSRR obviously helps, but there are real issues with managing the high return currents into a shared star earth.
An alternative strategy is to use a balanced circuit using Nelson Pass' "super-symmetry" idea. This is slightly more complex in practice than a single ended design - the main expense is the need for two pairs of output devices, rather than one. However, the ability share power supplies over many channels will more than make up for this.
I have some simulations that suggest this can really help, as you start off with very high intrinsic PSRR just from the balanced layout, even before the normal circuit measures come into play.
You get the added benefit that the SOA curves are more favourable because the load is shared across more output devices.
