If yours has a sleek black press switch with single round LED light then it will have had the Valhalla power supply fitted at some point. A Nirvana kit would have been included as standard back then. These will have put your 'spec' at pre 1984 SN <53000 Valhalla. Certainly, there may have been other 'upgrades' done. Regardless, no bad thing and a steal at the price you paid.
Somewhat dated, this is what has been floating round the interwebs for yonks as LP12 update history...
year serial modification
1993 90582 Cirkus LP12, Cirkus bearing and subchassis upgrade fitted as standard.
1992 88950 Top Plate with additional stud which improves the coupling of the top plate to the Plinth and secures the motor corner.
1991 87672 LP12 mechanics only, LP12 sold as a mechanical assembly only. Three power supply options available: Lingo, Valhalla and Basik. Valhalla and Basik (Basik PSU supplied with 45 rpm adaptor).
1991 87672 Trampolin kit, suspended base board available as an upgrade, solid base board replacing hardboard base
1991 87206 valhalla has motor thrust pad small cap factory fitted (glued in position) to reduce noise level.
1991 87047 lingo has motor thrust pad small cap factory fitted (glued in position) to reduce noise level.
1990 N/A Lingo direct coupled power supply for the LP12, offers low noise oscillators, precision filtering, separate drive for both phases and electrical isolation from mains supply.
1989 81000 Grommets composition changed to a new harder, denser rubber. Improves performance of suspension.
1989 79700 Motor thrust pad, motor thrust pad replaced with stainless steel ball bearing. Reduces motor noise.
1987 79160 Armboard material changed to MDF core, laminated top and underside. Increases rigidity of armboard, creating improved platform for tonearm.
1987 70000 Bearing housing, improved bearing liner material and thrust pad specification. Bearing liner machined to tighter tolerances, thus creating better speed stability. Changed to black oil. Tightened grinding tolerance.
1986 n/a Lid is changed for translucent type.
1984 54100 Sub-chassis, added strengthening bar, spot welded in place. Increases rigidity and strength. late '70s Attached strengthening bar with epoxy glue. Superior bond; increases rigidity.
1984 53000 Plinth, enlarged corner blocks, strengthens and increases rigidity of plinth.
1982 38800 Valhalla power supply, electronic speed control with a sophisticated crystal controlled power supply. Isolates the rotation of the turntable motor from variations in the electrical supply.
1981 32800 Nirvana kit Improved material specification of many integral mechanical components. Improved suspension and stability.
1979 27000 Lid and hinges lid prop removed and hinges changed to spring loaded, self supporting.
1978 23000 Top-plate added two holes for 6 x 0.5 self tappers into wood block
1974 2000 Main bearing liner material changed.
1974 2000 Sub-chassis strengthened by addition of strap, spot welded in place.
1974 2000 Motor control motor control pcb changed from terminal strip to small circuit board.
1974 2000 Mains switch changed from two buttons to single switch with mains neon.
1973 0000 Linn LP12 Sondek introduced
