Anyone using an adc into their mdac, or I guess other dac? I use the mdac as the hub of my system thereby requiring digitizing vinyl input, so I'm looking for recommendations for a high quality analogue digital converter with optical or coax output. Thanks in advance.
Werner, how does the beis fare against the tascam in terms of accuracy? I'm looking for a small form factor ADC with balanced in and preferably AES or optical out and don't need the features of something like a Tascam. I'm wondering if a simple DIY solution could be the way to go.
BE718, another great looking solution. Can feel a project coming on!
I can pm you a link to a recording if you are interested. You can compare the original file to one played back and re recorded through the ADC.
Many thx BE718, much appreciated. PM sent.
Build one of these.
http://www.diyaudio.com/forums/grou...tzeys-balanced-preamp-group-buy-part-3-a.html
If you are not happy with a soldering iron I know someone who may build it for you.
See the topic link you replied to. There's pricing, etc.I'm reasonably ok with some soldering, but really wouldn't want to build a complete circuit like this, so I would be quite interested in the "someone builds it for me" idea. What sort of cost would a fully built PCB be? I could connect stuff to it and put it in a box.
