Placing a 48"x24"x6.5" GIK Monster bass trap behind a Ditton didn't produce the result I'd hoped for. It narrowed the 135Hz null a little but actually made the 75Hz null deeper (
measurement here). Whether or not this would be audible is up for debate.
The bass trap has a beneficial effect on the 75Hz null when placed behind my listening seat (half way between the back of my chair and the rear wall), and this is indeed where I normally place it (
measurement here). However, since removing the trap from behind my chair my room looks a lot bigger and more light pours in from the window, so I might give it the boot!
Moving the speaker closer to the side wall improves the low bass response, but it pushes the 135Hz null higher in frequency and creates a wide dip in the upper-bass/lower-midrange (
measurements here). Note these measurements were taken with the cabinet flat on the floor, parallel to the front wall and approx 55cm from the front wall (measured to front lip of cab).
Here is the response of the speaker placed as close to the side wall (48cm to cab side) and as close to the front wall as is practical, toed-in so that the tweeter is aiming at the listening seat, and tilted back for the best treble response (
measurement here). This puts the speakers 2.85m apart (centre to centre) and a diagonal distance of 2.65m from the listening seat, i.e. the setup is slightly wider than an equilateral triangle.
The combination of the speakers being further apart and the broad dip in the upper bass / lower midrange pushes vocals further back into the soundstage and makes them sound lighter (i.e. less weighty). I also notice that the phantom centre image isn't as strong with the speakers placed this far apart, it's still there but isn't as obvious on some recordings as it is on others. I'm not sure whether I prefer the tonality and imaging of the Dittons in this wide and far arrangement or in the original Tannoy position, or in a position somewhere between the two.
This is the averaged left & right speaker response of the two positions:
And finally the averaged left & right speaker response of the new wide position after applying EQ mainly to tame the bass boom:
