Rega 'To Replace Motor (Planar old style)' said:IMPORTANT - DO NOT OVER TIGHTEN! Motor mounting screws are made of plastic to avoid over tightening. Therefore the screws will not reach an "end stop" and so cannot be locked off. Continued tightening after a firm fit has been achieved will cause too much compression of the 'O' Ring, causing the laminate to buckle and the screws to strip or the screw head to break off.
- Fit both mounting screws so that only a small amount of thread is taken up and the motor mounting plate is still loose.
- Position the pulley slightly to the rear of the hole in the plinth and central in the left right plane.
- With one finger, push the pulley down into the hole so that the top of the pulley is just below the surface of the plinth and is leaning slightly towards the rear of the turntable.
- Whilst holding the pulley in this position, tighten both screws. The motor will then bounce into its correct position when finger pressure is released.
- The drive belt can now be fitted. This will draw the pulley into its final position
Yep, and it might well be noisy too. Rega started using the sticky pads after changing to a newer, quieter motor iirc.Sean would need a new motor then, as the mounting flanges are intentionally bent down as hooks for the suspension O-ring. Pretty difficult to get these perfectly flat again.
The circuitry is incredibly simple but will run a little warm. It’ll probably be worth changing all the components out like for like, it won’t cost much and provided you’re handy with soldering, it won’t take long... then just replace the screw. An oil change and drive belt will then see it fit for service for a few years.Thanks all, very helpful as ever.
I had wondered about seeing to the board: I got the deck for a family member who lives quite far away so I’d like to future proof it as much as possible. I’ll post a photo tomorrow.
Thanks very much Steve, really appreciate it, but I'd say it will only be a pound on eBay.If you don't have M3 or want to go out shopping PM me and I'll cut one to length and post it. Let me know head type, if hex or cheese easy, csk may be trickier.
