lordsummit
Moderator
Natara is having a holiday from this thread.
When it comes to voice your chart gives a very different impression to for example http://www.bnoack.com/index.html?http&&&www.bnoack.com/audio/speech-level.html.
See previous posts.
Frequency response is but a single objective parameter of the multiple aspects that characterise speaker performance.
We know this but the graphs aren't just frequency response are they?-they also(assuming you actually followed the lecture) give us a good indication of in room behaviour too. So you don't think a 2-way topology is the right choice but then your technical expertise is what in comparison to the transducer and systems designers at JBL exactly? And you signally fail to highlight areas where the speaker is falling short or the substantiate your ridiculous 'not for performance' claim, produce evidence or I call BS.
No you've posted vague hifi forum lore/opinion, and 'rules' that are out of date ignoring the current state of play in network/transducer design, runs counter to some very well established and respected TOTL 2-way+ designs-again that's not evidence. Posting diagrams of musical instrument bandwidths isn't evidence either.I have listed several shortcomings.
I'm sure I would never be able to produce enough evidence to change your mind.
To quote Carl Sagan "You can't convince a believer of anything"
Good aren’t they ? I was very tempted to join Pos(Thomas) and go for the diy version but am happy with my 9800Be clones. Though suspect a 2216-nd may be on the cards.Found some measurements: http://www.audioheritage.org/vbulle...erence-Monitor&p=380278&viewfull=1#post380278
THD is higher in a 2-way
Well the THD measurements at 115dB are worthless...10% below 300Hz is very high but who listens at 115dB anyway?
The IMD+THD measurement is a bit cryptic thus again of little worth.
but
THD is higher in a 2-way:
Neumann 0 419 (3-way)
THD @ 95dB ~0.1% above 500Hz, 1% @ 50Hz, 0.1% @ 200Hz
Neumann KH 120 (2-way)
THD @ 95dB ~0.3% above 500Hz, 10% @ 50Hz, 0.3% @ 200Hz
IMD is higher in a 2-way:
http://www.neumann-kh-line.com/neumann-kh/glossary.nsf/root/F77C48111116FFBDC12578B20039968C
http://www.neumann-kh-line.com/neum...9025D8C4F126AD8C12578B2003A71E9?Open&term=TIM
I suggest you digest the contents of the Neumann articles tbh.Well the THD measurements at 115dB are worthless...10% below 300Hz is very high but who listens at 115dB anyway?
but
If I understand correctly the reason for more IMD is due to having one sole driver covering a wide range of frequencies. Single driver speakers are the worst performers, which is why their owners live on a diet of jazz trios and girls with banjos.Is that always the case? I can understand it in a tiny little two-way mini-monitor like the KH-120 where the bass driver has to really bob in and out to generate any bass, but what about an Altec VOTT, 15” Tannoy, Quad ESL etc where driver excursion is absolutely minimal at any sensible level?
NB ESLs work in a fundamentally different way; as pressure sources, not volume-velocity, and as such, if %thd and linearity is what you care about - you might want to look again at these 'single drivers'. Hint - they play anything well.
'Anything that doesn't have low frequency content.' Not true, at all.
Yes, if you had you would have read the following;Should I have them with tea?
Comparing a large 3-way with a bookshelf 2 way at 95 dB to illustrate the merits of a mid driver is a bit cheeky tbh. That 3 way you show has 10% harmonic distortion at 50hz at 95dB(it goes with the territory) the 10% below 300hz M2 is measured at 115dB.
So 2 ways of skinning the cat; the converse of the 'non linear nature' statement in bold must also be true so.....a decrease of 20dB in the test signal results in a far greater decrease in the level of IMD, and a decrease of 20 dB in the test signal results in a far greater decrease in the level of harmonic distortion.
