I was thinking of getting some elderly ESL63s restored, and as a longer-term possibility, thinking about building a pair of open-baffle sub-woofers to use with them. Motivation for this is not so much to increase the bass output, but to relieve the ESLs of some of the low-frequency energy, to give them more headroom.
So - I was thinking along the lines of an active system where the ESL power amplifier is fed via a high-pass filter (maybe fc = ~150-200Hz, 12dB/octave) while the sub-woofer is fed via a DSP system with a response derived via microphone measurement.
What I'm not sure of though, is how much this would really help. I wouldn't want to move fc to a much higher frequency because this would probably spoil the extreme clarity and coherence of the ESLs.
How does the peak excursion of a driver unit fall off as the high-pass cut-off is increased?
Anyone any quantitative knowledge of this?
Thanks in advance......
