Replacement on off switch for Naim 135
takemine1
I am after a replacement on off switch for a Naim 135..
Have looked on line, RS on line have a similar one but the connections look slightly different..pins different..
Maybe newer switches have altered..
Any thoughts..
what vintage?
Old ones have a modular EAO switch which you need to buy as a kit of parts and is ridiculously expensive, newer ones have a different design which is fairly easily replaceable.
Sorry to jump the thread but does any one know where to get a bulb for this switch (in my CB NAP 250) that's not so bright? It might match my newer equipment LEDs better!:)
I cannot for the life of me remember where now, but a few years ago I Googled replacement lamps for these switches, found a manufacturer and had some samples sent FOC! The ones I use now are LED based.
Edit: Found it. The company is Marl but I can't see a link to get samples. And the bulbs are "T6.8 Slide Base" type. But there will be other manufacturers out there who will send you samples.
Or maybe a couple of layers of this inside the plastic lamp cover?
Thanks for the info. Could be these might work if the voltage is correct? http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=271418032463
They should do. Some sage will be by shortly to confirm the voltage.
However that eBay item is very expensive. Check out RS. I believe they have re-introduced free shipping. But do search for manufacturers who may send you free samples ... ;)
Get the correct ones from TomTom Audio.
Cheaper than the ones you linked to on Ebay.
http://www.tomtomaudioshop.com/bulbs-9-c.asp
Dave.
Waste of money IME. They are filament and blow with boring regularity. I've been through handfuls of these .. when Naim used to pop them in a bag and send them FOC. But I've not had one failure on the LED versions I now use.
Agree about the filament lamps, but I'm sure they may have wrong picture.
They always supplied multichip led (white) in the past for that price.
Dave.
Dave.
Thats a rip off price. Here are the correct bulbs (I still have some) at a fraction of that price http://uk.rs-online.com/web/p/filam...5522677633D4E4F4E45267573743D3536342D34383126
You have to buy a pack of five but that is still cheaper than the price for one from your link. Also there is an insertion/removal tool in the pack.
Cheers,
DV
Cheers,
DV
Not CB 135 related but I've just changed two Uniti power switches in the last 2 weeks because the existing ones give up the ghost after a couple of years it seems.
I've still not found a modern equivalent for the 135/250 switch that doesn't cost a small fortune.
Always best to switch on/off directly from mains wall power socket .
Hi Dennis,
135s heh, good man.
If You pm me your address I will pop one in the post for You or have a ride down and I fit it for You for free either way
Best, Andy.
