I've started a new thread for the second revision of the generic PCB for rectification/smoothing (see old thread here). I'd like to keep the two threads separate, one for the low-power version, one for the high-power.
Without further ado, here's the design as it stands after much tweaking. Red tracks are the top copper, blue tracks are the bottom copper:
Edit: I've removed the pictures of the original board, the actual production design can be found at the bottom of this post.
I don't have prices yet, but they're likely to be about the same as last time at around $5 each (about 3 quid), depending on quantities. If we get over 200 orders then things change for the better
Cheers,
Carl
The most recent design will always be provided here. It'll save trawling through the pages looking for it!
- The PCB is exactly 120mm x 85mm. This will apparently allow it to fit in NAP140/NAP110 power amps, although I've not confirmed this. Another PFMer (can't remember who) kindly made the measurements.Edit: this was confirmed and there are pictures somewhere on PFM of folks who've done this.
- The diodes are TO-220 types, however axials would could be used if stood on end.
- Headsinking of the diodes is made possible by aligning the rear of the TO-220 devices with edge of the board. A long strip of aluminium or copper would do the trick nicely, and I'm sure other PFMers will come up with cool alternative ideas. If another run of these boards is done I'll adjust the diode spacing slightly to avoid the possibility of them touching. This was one of the design defects in the first run.
- The arrangement of the components and the silkscreen are all aligned under the assumption that most users of this board will require +/- power rails, not 2 + power rails. The board is perfectly capable of being used in configurations other than +/-, but the silkscreen won't match.
- The PCB allows for 6 capacitors of up to 35mm diameter. It's designed for snap-in capacitors with 10mm lead pitch, such as this 5600uF/100V: http://www.mouser.com/Search/Refine.aspx?N=11669746&Keyword=5600uf+smh&FS=True Edit: The board will take 6800uF/63V Kendeils
- There are spaces for 3 0V connectors at the noisy end of the board and 4 0V connectors at the other end. There are 2 output connectors on each power rail. Edit: there are a lot more 0V connections now!
- The inductor spaces have been placed to allow maximum room for axial parts standing on end. The pads have been enlarged and the through-holes are 1.67mm diameter to allow for very thick wire to be used in hand-made air core inductors. I couldn't use hand-wound inductors on the previous PCBs because my wire was too chunky to fit in the holes.
- The tracks are really, really thick and will be manufactured with 2oz copper, although I'd like to see how much extra it'd cost for 4oz.
Cheers,
Carl
