vinyl_paul
I have a Destiny Amp and have noticed a slight hum from both speakers under the following circumstances:
- Turntable disconnected from mains, but inputs attached to amp
- All other inputs disconnected
- Speakers connected
- Volume turned up (from about 12 o'clock onwards, 7 o'clock is off)
- Using standard mains kettle cable
Quick question: Is this an indication of something that needs service/repair? Or is it just an artifact of the amp and I should get over it? eg; yes they all do that.
Because there are no inputs, other than the unpowered turntable, I am assuming this is not the common ground loop hum? Turntable being powered on or not makes no difference.
