lAmBoY
They should still be. The OP is a dataset of 1.I came here because active ATCs were on my radar.
I leave thinking, simply, ‘WTAF?’.
No it is not the same, you missed the word "implausible". Though I do think blind tests are useful and interesting for things like amps and dacs which you would expect to sound similar, not so much for turntables and speakers where audible differences are definitely expected.However it’s the same for any component, amp, dac, whatever. You propose to close the forum?)
I wouldn’t worry about it, the substance of the OP is usually sorted out in the first few pages, five at most. We are now on page 30 and into the shits and giggles phase so little point in viewing if only interested in the OP.Hope the OP resolves his problem, whether it be using rugs, cushions or curtains certainly something to tame the room acoustics. However it could well be time to close this thread due to certain posters that appear to have taken over this thread as their own soapbox. Such a shame!
Any? Probably the most bizarre post I’ve ever read on this forum!I haven’t. Any experienced audiophile knows that cable difference can be way bigger compared to speaker or whatever.
Are you truly claiming that if I change a cable in my system the audible difference would be greater than if I , say , swapped my ATC 50's for a pair of Linn Kans?
This place don't need a wind-up to get wound-up.Maybe the whole thread is a wind up. It was the OPs first post here, and he hasn’t posted anywhere else on pfm. He has hit 50 posts though.
I take it you mean physical size? Agreed audiophile cable can be remarkably bulky and expensive, even though it does nothing for the sound over and above what any competent cable can do.I haven’t. Any experienced audiophile knows that cable difference can be way bigger compared to speaker or whatever.
Oh dear.I take it you mean physical size? Agreed audiophile cable can be remarkably bulky and expensive, even though it does nothing for the sound over and above what any competent cable can do.
Because something as implausible as power cables impacting the sound you hear is, without a blind test, more likely to be caused by factors other than the soundwaves being different. That does not matter a jot in one sense; if it sounds better to you then enjoy! It does matter though if it becomes a recommendation to others wanting to improve their systems, and even more so if it is a costly change for them.
Can you post some measurements showing the differences in power cables please.the differences in power cables and interconnect cables are measurable.
Ahhhh Alex, it's a trap..... I tried that in another thread and the measuring devices were the poster's ears. or the other excuse was the thing that needed to be measured was unmeasurable because no one had invented a "thing" that could measure it yet...Can you post some measurements showing the differences in power cables please.
Then it will be trivial for you to ace a blind test and demonstrate this. But you won't.I strongly recommend for people to try themselves. The differences, to my ears, are so profound that it's difficult to understand how some people miss them.
