6k Swiss Francs...thats 4.6k £6k for service is robbery.Ask Class a Shefield for quote.With shipping included you should save enough for Lp12.Switzerland is very expensive country,kind a Rolex service for naim
unfortunately it occurs with other sources too..Does the problem occur with every source you use, or just the CDS1?
Try another source and see if the problem remains.
which Richard do you mean? The guy from Switzerland?6K, ffs. TAke Richard up on his offer, it's only soldering a couple of caps and he has the gear and experience to find the faulty part.
thanks for your advice!Hi there,
I'd have to agree, there is a wealth of knowledge on the forum and common sense says that the amps will need recapping.
From past experience just out of curiosity I had my 250 and hi cap recapped after 18 years of ownership whilst waiting for a new pair of speakers.
The difference was jaw dropping I had never ever heard my system sound that good, I cancelled the new speakers and continued to use my Kans which had a new lease of life.
Over time you really don't notice the sound 'degrading' there was nothing wrong with my amps no buzzing hissing or any odd sounds but still obviously they really did need doing and whatever you can get them done for go for it, it wont' hurt and maybe you'll be kicking yourself you didn't do it sooner.
I have recently bought 135s and will be getting them recapped in the next few months, they haven't been done since 2009 and were used in an active system with another pair although I don't know if they were for bass or treble duties.
Good luck
you're very welcome, I'm actually going to call Witch Hat tomorrow regarding my 135sthanks for your advice!
Yeah it is quite a lot and not something I would do at the moment as I need my money for other stuff. Is anyone selling re-capping kits? I thought I‘ve read something a while ago somewhere..I know a few electro engineers and I am sure with the right components they could do the recapping with the help of the great 135 recapping post on PF£4.6k is still a huge sum of money. I'd contact witch hat and see what it'd cost to get your shipped and 135s serviced. Mark seems certain that's where your issue lies, he's an ex Naim engineer so I'd trust he's right. Worry about getting other components serviced in due course, unless you have the funds to get it all done at once... I'd still go to witch hat for a full system service, it's not going to adversely affect the value of your kit.
You could get it done locally. I'm not sure about re-cap kits, you just have to identify the bits you need and order them. The art is in ordering the best quality/suited parts for the application and of course good workmanship. An unknown/poor tech may use bargain basement parts which will work, but not optimally. And a really poor tech could damage traces etc.Yeah it is quite a lot and not something I would do at the moment as I need my money for other stuff. Is anyone selling re-capping kits? I thought I‘ve read something a while ago somewhere..I know a few electro engineers and I am sure with the right components they could do the recapping with the help of the great 135 recapping post on PF
Hope this http://www.hifi-repairs.com/naim.htm would be helpfull,they are on facebook now so you can contact them.Much less as I can calculate than 4.6k.They are naim oficial service.I will check them for my 250 service,easy for you to check via facebook or mail.As you have simlar problems with other sources you can eliminate CD for now ,and get focus on amp and SC servicing.I think it is 135's that makin you problems.6k Swiss Francs...thats 4.6k £
It doesn't look too bad to me, just a bit tedious as you have 5 or 7 similar or probably identical boards. Then a pile of reservoir caps, which are dead easy if not especially cheap. But its all conventional through board full size stuff. Most technicians will recognise this as being no more complex than a Mk2 Escort and just as easy to work on.he SuperCap in particular isn’t much fun to work on!
I am in Basel..do you mean help with finding the problem in the chain or help with recapping? Cheers, Gabriel
Could be that is the official Naim price. This is a guy you don't want from the sound of him.6k Swiss Francs..thats about 4.6£ ..he said thats the official Naim price..
As I bought my system second hand he didn't seem very interested in helping me and seemed rather annoyed by my call. Unfortunately, there's only one Naim dealer here so no other place to go.
