My Primare CD31 is getting increasingly problematic, so I decided to fit the replacement DVD transport I bought a little while back. A DLS - 710A.
The problem is that the transport is not the same. The mounts are spaced differently, the spindle covering is a metal panel not plastic, the connector/circuit board on the side that the Primare connects to is not even there. And indeed there is another connector on the rear that looks like an ATA connector. The design of the tray is different, too
I now see that because I found this photo of the Primare
http://www.gzhifi.com/ls/images/201206/1340149774855066791.JPG
I was recommend and bought the transport shown in the photo. And the DLS - 710A is often quoted as fitting my Primare CD31. But I can now see the inside of my Primare is a bit different, lacking that wide ribbon connector at the rear.
So, my question is – what transport do I need?
