The sample rate problem (which is fixed now) was spotted by everyone who played music with different sample rates.
It would appear that the Bluesound Node 2 streamer is not outputting bit accurate data...
If you have a PC to try via USB and reply a MQA file (again the PC needs to be set so that it outputs bit accurate data (no Volume control or up-sampling etc
I have a iFi nano iUSB3 which have 2 USB outputs, one with 5V and data, and one with only 5V. But I am curious how to best connect it. As I see it, there are 4 options:
1. Connect USB data + 5V into USB B on the DAC
2. Connect USB 5V to micro USB on DAC, and data + 5V into USB B (the manual says this it not good).
3. Connect USB 5V to micro USB on DAC, and data without 5V into USB B
4. Use a dual head USB cable to separate data and power from iFi nano and connect to USB B on DAC.
I have the UpTone USBA>B adapter that can disable vbus power, so option 3 feels like the best way (fully separate power and data), but then the USB symbol in the DAC display turns red and it don't work.
I have buy this device a few weeks ago on the e-bay.com (Germany's shop). In general, - works well for me, but I have one question to John.
Could you look on photo below and comment the fact , that at least one capacitor is absent (near front panel)?
Photo inside
Is this normally or this is manual input has place from somebody before sell this device?
P.S. Will be glad to test new version of firmware too
Bango,
Very odd, I suggest returning the DAC back to your Dealer for exchange - the Cap should be fitted.
