You state, if one thinks they hear a difference with a change of mains cable then the amp is design deficient, unequivocally.
It follows that you accept that mains cable may or may not make a difference to design deficient amps, otherwise why keep repeating it?
Mr ED
Your original statement is absolutist and deserved to be treated as such. You are now changing your original statement. If you wish to make absolutist statements and declare them as fact then best to think them through and correctly phrase them first time around. Otherwise you will appear as, and be treated as, a troll.
Btw should the amp be designed to be unconditionally unaffected by "normal variations of mains supply" or just the ones within the supplier stated parameters? The two are not always the same. There's also the issue that what is "normal" has changed somewhat over time. There's a lot more shit flying around these days than say pre 1975 (selected as a point in time before which there was very little in the way of microprocessors etc sat on the mains and polluting it with elements outside of spec).
No it is time for a 'Digital or Analogue which is the better source?' thread.
Should have at least 10K views.
Even though the simple answer is that they are both equal..
Or maybe a 'Power Cables Threads are they overhyped' thread..
I'm disappointed that Tony didn't take the opportunity to rename the thread Power Cables. Are they overhyped? Part II: Electric Boogaloo.Surely its time for "Power Cables. Are they overhyped? Part III"?
Why don`t all you DBT worshipers get together and build us the perfect Cable, Amp or speakers etc then you might be taken a bit more seriously.
So if you remove the lid from an amp which is transformed by said cable, what cable do you find from the IEC inlet to the transformer ? shielded ? mono crystal copper ? - no.
So the cable on the pylon to your house is bog standard ( not even copper), the cable in your wall is bog standard, the cable inside your amp is bog standard.
But you are convinced that some magic cable between your wall socket and your amp is making a difference ?
The only possible difference it could make is by causing interference into your signal cables, assuming you use non shielded phono leads.
As many experts also say you only need balanced shielded signal cables in a studio or if you have long cable runs..
Now, why don't all you foo worshippers try and make something by stitching together blind faith? Then we can all have a laugh.
The same technology and approach which enables us to explore mars remotely will do for audio - its good enough for me, at any rate.
Apologies, locked thread to split it, forgot to unlock it! Now open again.
I was enjoying the inky-black silence.
