Hoping I can get some suggestions on the best route - I have a Luxman SQ-n150 and Luxman DN150 CD player, both came with a power cable with a two pin power plug, neither cables look anything special. At the moment I have them running into a 2pin to 3pin adaptor. I really think I could do better, or are power cable upgrades really just hocus-pocus...
Power cable length needs to be about 1.5-2m, I hate short cables - budget upto £150 top each, ideally would like to pay much less...
Or should I just cut the provided 2pin power plugs off and put a standard 3pin plug on instead, if I go down this route, should I invest in some decent 3 pin plugs?
Thanks Paul
Thanks Paul
