I had one of those, and it was a stunner. It started as an m/m + m/c Art Audio Vinyl One, silver wired reference version. I then had a line input added with a source selector and a passive volume control, ALPS Blue with remote control.
It also had a gain switch on the m/c output to keep the noise down as it had high output m/c transformers.
I sold it to a guy called Brook a while back.
There are some images of the outside and insides here:
http://www.hifi-forsale.co.uk/morei..._Audio_Vinyl_1_Reference_+_Line&prod_id=41807
I sold it as I bought a Devialet, one reason being that the Devialet can be programmed for two phono inputs.
The fully spec'ed one I had you could probably negotiate from Tom Willis for around £2,500, less if not silver wired.
Before that I had a Tellurium Q machine that was very good, but not as good as the Art Audio valve one.
I got it from Analogue Seduction as an ex-demo, they still advertise it.
http://www.analogueseduction.net/ca...ng-coil-moving-magnet-phono-preamplifier.html
You could ask them or search for one, or ask Colin Wonfor if he has one or could source one. He might even be able to make you one.
I don't think it had remote control.
http://studio-hifi.com/images/HFW_ Apr12 TelluriumQ Iridium.pdf
