Before the fire I had built a music controller, sadly the controller which was microcontroller based was toasted by water and stuff and muck fell into it so it was deemed a write off, but I kept the rather fetching wood case as it was zebrano and I had a feeling it might come in useful.
Well it did...
As I only have two records I thought I would do something daft and stupid simply "because I can."
So I built a record deck, mostly from old secondhand parts on ebay, aftermarket rega upgrades, bits people do not want and the like. There is a thriving market for turntable add ons for the LP12 and the rega family of decks so I did some measurements are discovered the geometry would just about fit a 12" (305mm pivot to spindle) tonearm.
I drew up a cad design for the top plate and ordered the various parts and when I was ready I double checked everything and sent off the top plate to me machined in 10mm aluminium anodised plate.
It breaks a few cardinal rules of Regas and LP12s and I have still more to do, it also loses all audiophile cred as it has a USB port on it for a purely digital connection for direct ripping, should I want to do so...
Here are some pix...
Peek bearing too, woo...
More later, I will add graphs as well...
Well it did...
