JohnW
pfm member
Cool, thank you.
Can you please put me down for a DDA?
Bruce,
For sure , what's the rest of your system? so just to be sure you will get the best out of the MDAC DDA "unique" design - how will it be used...
Cool, thank you.
Bruce,
Hi John,
Great!
I'd be running the MDAC into either Genelec 8030a or Mackie HR824 MK2 monitors. Previously, I've just streamed to the MDAC, but could I just connect an external drive directly to the MDAC DDA or does it support an internal SSD... perhaps that's the FDAC I'm thinking of?
Cheers,
Bruce
Whats so special about the DDA Dac then it's discreet right? but what other features does it have? can you implement a crossover with it for example?
I run an active crossover and four monoblocks, ultimately i'd like to replace the crossover or have it tweaked to provide better performance, or get rid of it entirely and implement it digitally.
I've tried a pair of Ncore monoblocks and without the discreet buffer (ie just running on the standard input opamps they were ok but nothing special) with the Sparkos input boards they were much more interesting SQ wise
Thanks John.
John, if I may, ignore the naysayers on this thread. Sharing via PM what is of 'general' interest is inefficient... and we are all (or, rather, many of us are genuinely) curious about the different versions in the works!
Without the streamer and HQ PSU - the 1 & 2 will be around GBP250 to GBP400
The MDAC2 DDA is much more expensive (simply due to parts cost) at about GBP1200 price including the streamer PCB, but you then have to also add the development funding and donor MDAC.
These prices only apply to current MDAC2 / FDAC sponsors...
John, I was under the impression the discrete version of the MDAC2 would sound best for my needs, but if you think the DDA MDAC2 will be at least as good then I would go for that, I don't mind the extra cost. I also like the idea of an external HQ-PSU powering both the Detox and the MDAC2.
So the discrete DAC has the better "DAC" section, while the DDA has the better analogue stage.... I suspect there sound signature will appeal to different people.
FDAC will have the space to combine the best virtues of both designs.
