Mutec MC-3+ Smart Clock USB (Audio Re-Clocker & USB Interface)
This looks an interesting box. I'd be very interested in your observations on this - in a separate thread if you think that's more appropriate
Would you mind sharing a picture of those marvels?
Top shelf from left to right:
HDPLEX 100W Linear Power Supply (19V for HTPC, 9V for SOtM USB Card)
HTPC (Intel i5-4690T with passive cooling, SOtM tX-USBexp)
Interesting...
How do you fit the PCI USB Card into the Streacom FC5 OD?
The chassis offer just a horizontal Expansion Slot.
Are there any audible differences between the on-board USB port and the SOtM card?
Any news on the listening tests?!
You and me both!!!! all I can "hear" is that Opamp in my mind
Also, Michael has a Low noise PC so I wonder what effect the Detox will have in his system, that will be interesting...
I feel like a kid waiting for the school test results - not feeling as confident as I should be because of the Opamp...
Not 100% sure (can someone confirm, sincere apologies if I'm wrong) but I think this may well be 'Sovereign' who one of the versions of MDAC was named after. Sad news.
http://theartofsound.net/forum/showthread.php?50999-Farewell-dear-Friend
James Coltart - posted as Sovereign .
Very sad indeed.
Very sad indeed.
Most noticeable at this point is the improved sound stage reproduction including a remarkable seperation of instruments.
John,
Is it still possible to make minor changes to the Detox chassis? I had trouble fitting one of my cables because the cut-out around the USB Type B connector was too narrow.
it's not so easy to quantitate the improvement because I can't do direct A/B comparisions at the moment.
How much larger do you need? (By "B" you mean the Square lead cutout from the PC)?
