My 1984 LP12 had the original mdf armboard but it bent after decades of supporting the weight of the Ittok so the azimuth was way out. The problem with the early steel kite shaped sub chassis is that the arm is completely supported on the end of the armboard dangling in mid air! Also, the bearing can distort the chassis where it’s mounted causing misalignment of the platter.
So I bought a second hand cirkus aluminium sub chassis and an Audio Classique ceramic armboard.
Now the biggest hassle in setting up an LP12 is aligning the armboard in the plinth cutout while simultaneously getting the bounce correct. This involves twisting the springs which I’ve never thought was a good idea and can take hours. So what I did was enlarge the 3 arm collar screw holes in the subchassis to 7mm and the arm rest pillar hole to 10mm, giving some wiggle room. Then all I had to do was set the springs central and in their natural position without any twists etc, set the height, align the armboard in it’s cutout then tighten the bolts. Dead easy, faff free and the bounce was automatically correct.
After this I fitted a new cart and took great care with the set up. The result was far better sounding, very detailed but maybe a little dry / hard sounding and lost quite a bit of its warmth.
So thinking about this thread I tried loosening the arm collar bolts but it didn’t make much difference.
Finally I cured the issues with the sound by cutting out a piece of thin card to the shape of the armboard with holes where all the bolts go through. Now the armboard is basically mounted with a piece of card sandwiched between it and the sub chassis, The bolts are just finger tight (Tony L is a great believer in finger tight bolts on turntables). Sounds just wonderful now, all the original warmth and super detailed. I think this is how an LP12 should sound.
Oh and a blue belt helps a lot too.
Was a complete newbie to LP12s a few months ago but by no means an expert now.
