ICs are not routinely coax.
This is news to me. There does exist something called twinaxial cable but that’s a different thing. There are reasons why single ended shielded signal cables are coaxial. It’s to do with the need to have the shield at a constant distance from the conductor and having the geometrical centre of the signal and return coinciding.I reckon screened twin ICs cut an enormous amount of noise here. Try some and see what you think.
I use the Klotz - a microphone cable and quite large. The Klotz is low cap'. Shop around and the Klotz in particular can be bought for peanuts
So if you are making your own then move up from Klotz and the other coaxial types and go twisted pair with higher class cable. You will be surprised at the better sound you will get.
That is what the Klotz replaced here - twisted pair, PTFE etc.. Klotz far better.
Everyone's ears and systems are different. For me, the difference is between shielded and not, but I have used very few different ICs and would never pay "silly" money for any cable.
I don't want to get bogged down here but@adamdea, you are the only person here to mention coax.
Strictly speaking coax (short for coaxial) cable/flex is two conductors that are coaxial and most frequently are a conductor and a screen. To be coaxial, there is no other configuration possible, except multiple concentric (coaxial) "screens". In many instances, the centre conductor is actually solid (cable), not muti-strand (flex). It is typically used as aerial lead.
Hifi ICs require two conductors. There may or may not be an additional screen. The conductors may or may not be coaxial, if they were coaxial it would have to be in the same configuation in the cable, as a screened single cable - typical "coax".
High quality microphone cable is typically screened twin, so can fit the bill as a screened hifi IC.
But if you want to get maximum screening protection from an rca connector (which did seem to be the point of the OP) you would want to use coax.
In typical short high level analogue 'hifi' interconnect applications the cable format is really an irrelevance .they all work just as well as one another,
Nope that's really is how coax cables work. I'm afraid this is just one of those things which is counter -intuitive but true.No, no, no, a hundred times no.
Coax is two conductors. There is no screen if used as an IC - what should be the screen is used as a conductor.
If you want a screened IC, you MUST use screened twin.
I'm in New Zealand - it's very kind of you to offer.@DNZ - where are you? What length IC?
I have some spare Klotz/Neutrik Profi IC's here. Pay for postage and you can try them, if you like them, they are yours for the cost of parts (Neutrik Profi are not cheap, the cable is and even I usually foget that a pair of IC need two pairs of plugs whenever I go to make up another set).
Use PM
