I've just got hold of a gutted 32.5 , mother board only and the case. Now I intend to use Avondale 821 boards and a single input (CD) I'll fit phonos to the holes where the BNC's were, one pair for the input and one pair for the output. I'm going to ignore the selector switch ,the mono switch and the tape monitor switch. Is it OK to wire the input direct to the volume pot (50K Noble) , without using resistors inplace of the balance pot , then run the volume pot direct to the 821 boards , the 821's will be dual railed running off a TPX1 , then the output fed straight to the phono outs. All 0volts will go direct to the star erth point....cheers ...Jon
