Looking to change the belt on my P3-24 and most of the shops were sold out of the Rega White Belt. So I decided to try the Edwards belt. Two things that I have discovered. First off the sound appears to be considerably brighter than the stock rega belt and perhaps I am hearing either more surface noise or motor noise. Or perhaps it just sounds louder. It's almost digital in tonal balance compared to the stock belt. Less organic if you will.
Secondly it appears to be running slower as well. The belt is obviously tighter than the stock table belt and while that one is running a bit fast I assume it is due to the age and it being stretched out more from use.
My gut is to return it and wait for the white belt. Anyone else out there notice these observations?
