I'm using Capture One pro.
While reading a lot about mirrorless cameras, I was leaded to the DxO site and I downloaded the DxO pro 10 for trial. I find the DxO much easier to use and not as loaded as the Capture One (not an advantage for all). The "dust remove" tool far away better with the DoX than with the Capture one and this tool is very important to me. The app is also setting automatically each picture for better exposure and colors (which can be reset if you don't like it - but it does a good job to my taste).
Do you have experience with this app?
Arye
Arye
