martin clark
pinko bodger
That looks a lot healthier.
Yes the 797 is very senstive to implementation, particularly the value/location of any cap on the output: depending on current demand , location and wiring this has certain requirements of ESR and uF value for 'domnant pole' -based stability. The compensation for the flea is setup ..for the specific use. You can do wilder things with it, but it has to be checked with a scope each time - as with any high-bandwidth circuit That's the second real utility of the small-value resistor in the opamps feed on flea- a quick sanity check on total draw by the 797.
