Thanks all, very humbled by your comments.
@Tony L, let me try to address your notes separately.
Multiple Motors
When I started looking into designing a turntable, after owning a number of (albeit all belt-driven) turntables, I decided that whatever the approach, a high torque motor would be used. The thinking behind this was that if I decide to change the concept I could have some leeway. So I ordered a number of high torque BLDC motors, and originally built multiple motor pods (at one point I had three motors driving the platter at the same time). That approach brought a level of complication on the drive electronics as the motors are rarely matched and suffer from varying torque curves.
There are many examples I've seen. One very interesting to me is the Audionote TT3 which, according to Audionote, uses three high torque motors and a very light platter. Another approach, that I don't really like based on photos only, is the Acoustic Signature Invictus with its six motors - I don't understand why six of them but I reserve the right it may serve a proper purpose. Then there is Kuzma, who is notable by the fact that, for his reference turntable, went from two motors, to four motors, then to one motor. He justified the changes as going from AC to DC motors, but I've always felt (although unconfirmed) that such an approach is to simply provide an upgrade path for those willing to do so.
But with testing and several years of operation, I've concluded that adding up on motors (these BLDC motors) actually yields much less benefit than the added complication of the drive electronics. As long as the single motor is competent, of course.
Split Platter Design
My initial driving idea was to figure out a way for the bearing spindle to have as close to nonexistent contact with the playing surface. Typically bearing spindles extend to the actual record spindle, but I felt that one way to minimize bearing noise is to eliminate that contact surface. One could make a fully magnetic bearing, but I shied away from that approach since I feel that mechanical grounding needs to exist, and wanted to avoid spring-like behavior from magnets. That of course required quite a massive bearing, which I've elaborated on earlier.
So I drew up the original split platter where the bearing spindle makes contact only with the lower (high mass) platter, and the record surface makes contact with only a "mat-like" surface that rests on the lower platter.
Now, there are inherent complications to that approach. One cannot make the top platter as thin as I wanted (mat like) since it would have little to no rigidity. So I went with a minimum thickness of 15mm initially and the next item was coupling - I wanted to have as little contact as possible to avoid vibration/noise creep-up. Settled on a tri-point support, and used high grade ceramic balls due to both their load bearing capacity as well as the very high level of sphericity guaranteeing as little as possible contact.
I did a few experiments with only a high mass platter. Quickly dropped them as, while I clearly saw the advantage that huge rotational inertia brings to the game, I also felt that music was, for the lack of better words, sucked out as if overdamped. Adding mats and or other paraphernalia yields it moot from a simplicity perspective and I'd rather not bring solutions to problems that I could easily avoid by updating the concept. Which brings us again to where we are.
Material wise, aluminium was a clear choice for the high mass platter as it is machinable, available, and non-magnetic. I did think of bronze at one time, but I failed to see the advantage of adding close to three times more mass to the platter, not to mention the prohibitive material cost (the bronze blank required alone would be in excess of £1K).
For the top platter, I wanted to experiment with PVC as I felt it would be as close to actual records as possible, especially from a vibratory standpoint. I quickly learned why people do not use it (it destroys tools when machining, absorbs cutting liquids and very much releases chlorine). I tested all the various popular alternatives - glass was a no go, acrylic was just dead sounding (but it is cheap and easy to machine so I guess I understand why so many turntable platters are made of it), even whipped out a PTFE sheet, but ultimately settled on POM as it was as close to PVC as possible, while proving to be a joy to machine and remain stable. And it is also light (only 2% more dense than PVC).
