Hi,
Just finishing off the boxes of my first speaker project. I am using jx150 and jxr6 drivers in a sealed 50L cabinet.
My question involves the the wiring of the 2nd order crossover i will be using.
Due to the size of the components and for conveniece the x over will sit on a draw that can slide into an integrated stand. Only the bass inductor will be inside the speaker.
What is the best way to join the wiring and components to the binding posts?
I thought to run everything to and from the posts themselves, directly soldering everything together at the respective post.
Or should i use a common ground wire and connect everthing at a point away from the - ve post.
I hope that all makes sense and thanks in advance.
