mikesnowdon
resU deretsigeR
All done with no smoke or burst capacitors and playing music rather well indeed. Initail listening is very promising, David Gilmour - Live in Gadansk sounding very natural and refined. Bass sounds better defined and detail is improved, the slightly muddled mid is cured now also. The overall tone is quite warm yet retaining good detail seperation and dynamics. Top end is clean and extended.
Ive not done anything with the row of caps directly behind the phono sockets. I tried to trace the PCB traks to verify if they were signal decoupling caps but I wasnt certain so left them alone. I know the most obvious purpose for these caps would be decoupling but untill I can be 100% certain I'll leave them alone. I have a spare pair of Mundorfs so I can use these but as there are allready quite a few decouplers in the signal path I might be ok to link them out.
Apparently LM4562 give next to no DC output so when I get a meter I'll check this and may be able to remove a few caps from the signal path.
I left the caps before the opamp/selector-chip regs alone as Im not sure if replacing them with big 4700uF caps is the right thing to do. I also need to find out why the + and - rails have different value caps first. 1000uF on pos rail and 470uF on negative. ???????
Obviously replacing the regs with Teddy's would be good but I need help making a pair really. The assembly is no problem but Im not sure about setting the voltage?
Here's some piccys:
Winny approves
Here's some piccys:
Winny approves
