Allan Probin
Any opinions on the performance of these two similarly priced 'speakers when used in a normal domestic environment at typical medium/moderate volumes.
Physical differences I can see are:
The SCM20 Pro's have the "S" spec tweeter, I see it has a more powerful magnet assembly and therefore has better sensitivity, but is there much noticeable audible difference between this and the standard tweeter?
The SCM20 Pro's have 250W+50W power-amps, vs 150W+35W in the 19A's. Will this assist with peak musical content, even at moderate volume? Will the bigger amps help with grip and control at the bottom end?
An SCM20 Pro weighs about the same as an SCM19 tower. As both speakers, for all intents and purposes, use the same drive units, and I doubt the more powerful amps in the 20's add that much additional weight compared to the 19's amps, so it seems likely that the SCM20 cabinet construction is heavier, stiffer and better damped than the 19's.
I think I'm talking myself around into believing that the SCM20 Pro's should sound better, but is that borne out by the actual listening?
