John_73
Hi folks.
Having nearly finished my Garrard 301 project, my attention has turned to my Quad systems. I have a Quad 34/606 and a Quad 22/II system. All have been recapped, with a few light tweaks here & there to the Q34.
What I'd like to do is raise the output of the Q34 to 1.6V (easy enough to do and detailed in the manual) so I can use it & its superb in-built phono stage with my Quad IIs over the winter months. I don't want to have to keep changing resistor settings every time I change power amps though, so wish to keep the Q34 at 1.6V output, and see if I can increase the 606s input sensitivity to the same. Is that possible to do without massively changing the basic circuit or making it measure/sound worse in any way?
Thanks,
John.
Thanks,
John.
