Having tried out a Roksan Nima on my Garrard 401 with positive results, I am now keen on trying out a 12 inch unipivot arm - ideally something that's not too difficult to set up.
Only thing is my armboard that allows 12 inch arms has a rega sized (23mm) mounting hole and I dont want the hassle/cost of getting a brand new armboard made right now.
So, what are the options for 12 inch unipivot arms that would fit a rega mount? with or without an additional adapter.
Happy to buy an additional adapter to convert to the Rega mount hole if thats an option.
I know the Opera Consonance 1288 arm fits the bill but seems to be difficult to get hold of.
Any other options to consider?
The Nottinngam Analogue AceSpace 12 inch version looks interesting but not sure if I can get an adapter to fit a Rega mount.
All advice much appreciated!
I would probably be looking at used arms with a budget of £400-700
