James Evans
Bedroom Bodger
Just noticed tonight that the zener resistors (680R, 3W, welwyn W21) in my claymore are pumping out vast amounts of heat. The voltage drop is 25V. Not sure if this heat is correct or not - not noticed it before. Any ideas? The voltage output should also be +-16V and I'm only getting +-14.5, which doesn't bode well I assume for my TPR regs outputting +-10V (lt1086 and lt337).
Based on calculations, IR is 35mA. I'm supplying 4 lots of TPR regs (2 lots of +-) with voltage refs, into 2 AD8620 opamps. Now if the current draw of all that is more than 35mA what would happen, would this cause the excessive heat?
I have 2 sets of zeners (identical) running from the same +-41V lines - the 2nd set are outputting +-16V no problem, although the resistors here are also v hot - they are attached to the other resistors at the 41v end though, so I guess it may just be transferal of heat....
One thought - I could always dump the zeners altogether and input the 41v supply to the tprs, but they'll be dropping 31v, so I'm assuming I'd need to invest in some serious heatsinking?
ta
James
ta
James
