Just need it to be able to change the preset stations - the original Quad 66 console-type remote is available with the unit which can be used to actually save presets on the tuner - I just want a smaller option for daily use.
Looks like the remote for the Quad CDPreJust need it to be able to change the preset stations - the original Quad 66 console-type remote is available with the unit which can be used to actually save presets on the tuner - I just want a smaller option for daily use.
