White noise problem
Discussion in 'audio' started by ks.234, Apr 8, 2021.
  1. ks.234
    ks.234 pfm Member
    Given an old pair of speakers, Topping Amp and an Audio Alchemy Dac-in-the-box to my son to connect to his newish Samsung TV using an optical cable. All he gets is white noise.
    He seems to have connected all the wires properly and set the TV to Optical output, but still just white noise that will go up and down in volume when volume on amp turned up or down
    Any suggestions?
  2. Vinny
    Vinny pfm Member
    Is there any option but optical?
    If there is, worth a try.
  3. a.palfreyman
    a.palfreyman pfm Member
    What about TV headphone jack > Topping > speakers. He will then have remote volume control via TV remote.
    ks.234 likes this.
  4. ks.234
    ks.234 pfm Member
    Unfortunately not
  5. webster
    webster Listen & enjoy.
    Try another optical cable?
  6. ABCaudio
    ABCaudio Trade: ABCaudio, representing EWA
    It could the DAC isn't locking on. There should a setting on the TV somewhere where you can check the format it's outputting at the digital output. It has to be PCM.
    Although I don't understand why the volume would track in this case.
  7. ks.234
    ks.234 pfm Member
    Tried that, no difference!
  8. webster
    Does the 'locked' sign illuminate on the front of the unit?
  9. ToTo Man
    ToTo Man the band not the dog
    Does TV have menu option to "downmix Dolby to PCM"?
    Millennium likes this.
  10. ks.234
    ks.234 pfm Member
    Two lights come on, on the dac, one for power and I presume the other is for a signal?
  11. James Evans
    James Evans Bedroom Bodger
    As suggested above, does the tv have digital output format in its menu settings as an option? It needs to be set to PCM if so. Other than that, are there any other devices with optical out that can be used to test that the setup actually works?
    webster, Cav and Wilson like this.
  12. webster
    I believe so - which would rule out the optical cable being faulty in any way.
    I use the optical out of my tv (which is probably around 10 years old) into a Node 2i and it's true you need to make sure that it's set to PCM.
  13. Amber Audio
    Amber Audio This is the Day
    Model number of TV would help.
    Try setting TV to digital audio output as PCM and the sound output to the TV speakers, unplug optical cable, plug back in.
    I think Sammy outputs at 48kHz, those old AA DACs go up to 50kHz so that should not matter. I don’t think they had a manual switch for CoAx or Toslink, it should auto detect.
  14. ks.234
    ks.234 pfm Member
    That’s what I thought. It’s a Samsung 43 Inch UE43TU7000KXXU Smart 4K Ultra HD TV with HDR
  15. Amber Audio
    ks.234 likes this.
  16. ks.234
    ks.234 pfm Member
    Now Sorted! Thanks to all you wonderful people. Thanks to @Amber Audio we finally managed to find the option for selecting PCM. Had to reset all the sound options to make the PCM option appear in the drop down box, it reappeared like magic and my boy now has sound!
    Many thanks everyone
    webster, Amber Audio and martin clark like this.
