I have just built a Salas DCG3 preamp. Initial impressions are extremely favourable, it appears to be rather special. Details can be found here: https://www.diyaudio.com/forums/analog-line-level/296406-salas-dcg3-preamp-line-headphone.html
I am in the process of completing the build and am thinking about the best solution (for reasonable money) volume control. One option is of course a potentiometer, but which one, there is such a huge range in terms of price. I feel drawn towards a stepped attenuator, indeed I have one made in Taiwan with Dale resistors, that seems pretty good. Though I am also drawn towards the Khozmo series attenuator https://khozmo.com/series_khozmo_attenuator.html
Other people make a lot of positive comments about LDR based volume controls, whilst others claim there are issues with non-linearity, which puts me off. Alternatively there are the relay based volume controls. I tried a cheap one form Ebay and found that both the input and output resistance changed continually at different settings, so am not convinced that this is the right thing to use. I know other types are available at a number of different price points.
Having tried to read the arguments for both different types of volume controls as well as discussion of DACT over another, I now fully completely confused. Given that some of these items are quite expensive and I don’t want to make the wrong choice. I was therefore wondering if anybody has any practical advice based on having actually having heard different options.
Ian
Ian
