drummerman
Is the Fuji 16-50mm f3.5-5.6 XC OIS a good choice as an all-round lens or should I stick with a prime?
I only really want one lens to deliberately make me work harder at composing plus I don't want to carry lenses around.
Also, are there any macro rings I could use?
I am undecided yet between a cheap XE-1 and perhaps a OM D-5 or 10. Perhaps even a small DSLR bit I guess there is little point as I won't buy into a huge lens system. However, if the quality justifies it I will perhaps go that way.
Main criteria is to be able to put it into a small back pack or man bag (Courier style) without weighing me down to much. Finally some robustness would be nice.
Also, I will probably want to make the odd large print, small poster size (larger than A3) without impairing quality. Is this possible with any of the above?
Any advise much appreciated. I am getting more confused the more I look into it and that's exactly what I want to avoid. Photography first, hardware a long second.
Thank you.
Thank you.
