This is my first ever foray in the DIY forum! Hopefully this is the best place for my questions.
My Kingsound King electrostatic speakers were powered by walmarts - AC/DC adaptors with output rating 12V DC 250mA 3VA, tip positive.
I say "were" - my son has just managed to trip over one of the wires and rip it out of its moulded housing.
Rather than try to get it repaired or buy a (cheap) replacement, I'm thinking to use this as a prompt to get some rechargeable batteries instead, the theory being they will sound better and hopefully provide a better quality to cost ratio than a pair of high-quality expensive power supplies.
But I'm clueless on what kind of battery to buy.
Is my best option a sealed 12V car battery? I understand that the amount of time it will last is specified as Ah, but does the current rating matter, or will the speakers simply draw the current they need? In which case should I simply go for the biggest Ah I can afford (and cope with aesthetically), and safely ignore the current rating?
What kind of charger should I buy? I imagine the best solution audio-wise is to have a charger I can plug in when not using the speakers?
Can I connect the battery terminals directly to the wires of the broken walmart cable (ie do the +/- battery terminals correspond exactly to the outputs of the adapter)?
Sorry if these are stupid questions - any help is much appreciated.
Many thanks
Mark
Many thanks
Mark
