What DAC are you using to connect your Smart TV to your hi-fi amplifier ?
Discussion in 'audio' started by Alun Rains, Oct 21, 2021.
  1. Alun Rains
    Alun Rains Jus Juan Cornetto
    Hi Guys
    Just wondering if you are using a DAC to connect your Smart TV to your stereo hi-if amplifier and if so, which one. Looking for good recommendations that don’t cost the earth.
    I am currently using a CYP-AU-D3-192 DAC from Richer Sounds that works OK but I do find it can seem to become overwhelmed at times and the volume can fluctuate momentarily.
    I am not interested in sound-bars or surround sound systems..
    Look forward to your replies
    Snufkin likes this.
  2. JensenHealey
    JensenHealey pfm Member
    Optical connector from from TV (Samsung) to my Pro-Ject pre S2 digital. Works great. Same Dac has USB feed from my Mac Mini ( for Roon/local music/Qobuz). Also has digi coax from my Marantz Universal player- but tbh that is connected via Phono to the Amp and the digi coax largely unused.
    Alun Rains likes this.
  3. GavinB
    GavinB pfm Member
    Chord 2Qute via optical
  4. Del monaco
    Del monaco Del Monaco
    Dacmagic 100 would be a decent choice unless you wanted to take a punt on an internet Topping or SMSL.
  5. moo-fi
    moo-fi pfm Member
    Old Rega via optical works just fine for us.
  6. JensenHealey
    I should have said that I previously used a Dacmagic 100 - easy to connect and a small unobtrusive box too - although like most small DACs you have to hide a power brick somewhere too.
    Alun Rains and Del monaco like this.
  7. RoA
    RoA pfm Member
    I just use the integrated DAC's on my amps but I had a DAC from these people which did a good job.
    https://hifimediy.com/
  8. hifinutt
    hifinutt hifinutt
    teac udho1
  9. Amber Audio
    Amber Audio This is the Day
    In the past I’ve used the little Fiio/Maplin uber cheap £20 ones and then a Dacmagic 100, still have the Dacmagic but it’s been moved to the SONOS rig, got it for a good price off eBay last year and can recommend it. A Topping E30 would do the job also.
  10. GruntPuppy
    GruntPuppy pfm Member
    Arcam SR250's inbuilt DAC for me, via HDMI.
    Finding it to be rather nice.
  11. flutteringwow
    flutteringwow Platinum Ears
  12. coredump
    coredump Press <ALT-F4> to continue.
  13. calorgas
    calorgas Ratty bumpkin
    I use a cheapo FiiO jobby I bought via ebay. It works fine and has been plugged in 24/7 for ~18 months and has worked perfectly throughout.
    Alun Rains and narabdela like this.
  14. MotelBlues
    MotelBlues pfm Member
    Having a dumb TV and no television licence, my only video source is an elderly BluRay player, which gets DtoAd by my Hugo.
  15. SteveG
    SteveG pfm Member
    Another DacMagic user here, although we used to use one of the little FiiO ones. That worked fine as well - only changed it when I changed the system and it had the DacMagic available anyway.
  16. yeti42
    yeti42 pfm Member
    I recently used a Rega DAC-r via optical. Maybe a bit too dynamic in a terraced house with close neighbours. Loud enough to pick up the dialog was a bit too much when things blew up, as they so often do in SciFi and crime dramas these days.
  17. coredump
    yeti,
    not sure if you are using streaming services, but some of them offer a "normalize" option in their settings that reduces dynamics exactly for this reason. Maybe some TVs also offer that option in their firmware, might be worth it having a look.
    Best,
    Oliver
  18. Alun Rains
    Thanks everyone for your replies.. Gives me several options to explore further.
  19. legacylenslover
    legacylenslover pfm Member
    Fiio D03k. about £25. Optical and co-ax in.
    Recently moved it on only because I now have a Schiit Modius which undertakes DAC duties for multiple devices.
  20. Mike Hughes
    Mike Hughes pfm Member
    Tried it through my Hugo TT2 but it sounds better as analogue.
