Hello,
I am thinking of replacing the output caps of my NAHA Naim headphone amp with Elna Silmic or Cerafine caps. The current caps (blue Rubycon) are 1000uF, 35V and are roughly 25mm x 12mm, and I have a total of 32mm from the PCB to the top of the chassis. To get a 1000uF in the Silmic, the 16V version is 31.5mm and the 25V is 35mm. Do you think I could get away with a 1000uF, 16V cap? I believe the internal voltage is lower, but would appreciate your opinion. Also, any opinions on using a Silmic II vs Cerafine caps? Any other caps in the Headline that I should consider changing while I am in there?
Thanks in advance.
Jim
Thanks in advance.
Jim
