Washing Machine Hum and Buzz
Discussion in 'audio' started by Napzca, Jul 30, 2020.
  1. Napzca
    Napzca Active Member
    The Washing Machine is causing my Amplifier to hum and buzz loudly. Is there a way to rectify this? I only have one ring main for my sockets. Could there be a leakage of current to the Ground or is it causing distortion of my waveform? Can I filter out the noise by plugging a filter before the washing machine? Would a separate ground remedy this? Your help is appreciated.
  2. thebigfredc
    thebigfredc pfm Member
    I am no expert and I can’t claim to have ever connected an oscilloscope to the output of the mains but received wisdom says transformer hum is caused by a D.C. offset on your supply which I am not sure tallies directly with your washing machine theory. Anyway I am sure somebody will come along shortly and put us both straight as is the way on PF.
  3. hp1
    hp1 pfm Member
    When you say noise from your amp do you mean through the speakers or mechanical noise from the transformer.
    Afaik washing machines have dc motors to get the speed range between wash mode and spin mode.
  4. Barrymagrec
    Barrymagrec pfm Member
    Do not under any circumstances connect an oscilloscope to your mains unless you know what you are doing.
    The likely problem is spikes being put on the mains by the washing machine, which may be faulty. A suitable filter may help, or do the washing when you are not listening to music.
  5. Napzca
    It is mechanical hum of the transformer. I am worried the vibrations in the transformer are doing it damage ie could degradation of the toroidal transformer occur causing more hum? The washing machine seems to work ok.
  6. hp1
    hp1 pfm Member
    It could be the washer power supply perhaps a new one is not too expensive.
  7. hp1
    hp1 pfm Member
    Also try plugging the amp in right by the washer, less mauling than the other way round.
  8. Barrymagrec
    The fact that the washing machine seems to work O.K. doesn`t mean it`s not faulty, it`s own suppressor may be faulty or some problem in the motor circuit could be causing excessive noise on the mains. What about other equipment on the same circuit - TV for instance?
  9. Napzca
    Don't want to replace the washing machine it's only a few months old. The interference doesn't affect any other equipment. Just the Amplifier.
  10. JensenHealey
    JensenHealey pfm Member
  11. Darth Vader
    The xformer buzz is caused by DC offset on the mains. If its the washing machine causing this then it may be missing or need a transient suppressor wired across the motor. It sounds grand but its just a resistor (around 100Ω or so) and a suitably rated capacitor (around 0.05µF) in series across the motor. Sometimes you can buy these as a sealed suppressor unit.
    Cheers,
    DV
  12. Napzca
    Thanks DV. Better than buying a new washing machine.
  13. Napzca
    I tried a Tacima Mains Filter, it didn't have any effect. Thanks DV you were right if I put a humbuster III which blocks DC voltage on an AC line it stops the hum, but I don't want to use this long term.
  14. Napzca
    Will this motor suppressor do the job? What does U, V and W stand for?
    [​IMG]23050_zoom by Napzca, on Flickr
  15. Beobloke
    Beobloke pfm Member
    They refer to the three phases on a three-phase supply. No good for your machine as domestic mains is only single phase.
    That's also rated for use at 400Hz so is intended for aircraft ground supply systems!
  16. Darth Vader
    Are you in the UK or Europe? In the UK our domestic supply is single phase and this is the sort of thing I was talking about https://uk.rs-online.com/web/p/surge-suppressor-units/0240393/
    However unless you really know what you are doing wrt to mains electricity I'd suggest you get someone qualified to do the work. Before that why not disconnect the machine from the mains and check whether there is already a suppressor fitted across the motor and if so is it still properly connected.
    When I lived in Germany we had a 3 phase mains supply so things were wired differently.
    Cheers,
    DV
  17. hp1
    hp1 pfm Member
    Sounds like the washing machine is faulty, maybe a warranty claim is order
  18. Napzca
    Sadly can't claim warranty due to Covid. Will have to wait till there's a vaccine.
  19. Napzca
    DV I will check the motor thanks
