Mike Reed
I thought I'd try out these replacement adhesive felt strips bought from eBay (link) for £8 for 4 strips.
I've just gone through the rather fiddly and painstaking task of doing this, and, judging by 6 LP sides I've just cleaned, they work well.
Removing the adhesive from the tube was very difficult, and 99% IPA wouldn't do it alone. I used a Stanley knife, scraping very lightly, interspersed with IPA, until the tube was clear. I also IPA-ed the inside for good measure. I guess it had the advantage of creating 'key' for the new pads, anyway. These strips are wider (x2 at 10mm) than the originals, but that proves to be an advantage when fitting, and doesn't interfere with close contact with the record.
One warning, though. I found that the black housing to the tube had a thin black caking throughout. It seemed like vinyl shavings which had, through 1500+records, coated the sides. IPA and cloth cleaned it easily. Of course it wouldn't affect the record, but would influence the egress of waste fluid in the tank and pipe.
So far, they appear to be fast, stand up to brushing the detritus off after each clean and provide good contact.
Compared to a complete replacement tube at £30, this represents a good deal, if, that is, you're prepared for half an hour of fiddly work. Alignment along the slit is fairly easy; not that I'd consider it crucial, anyway.
