Voyd reference
Discussion in 'audio' started by jackal2513, Nov 22, 2010.
  1. jackal2513
    jackal2513 pfm Member
    any good ?
    seen a secondhand one which might be interesting to build up to something tasty ?
  2. stevec67
    stevec67 pfm Member
    One was at the bake-off, it was very nice. I must admit it didn't especially groove my truffles, I liked the Lenco for its extreme cheapness, the WTA for its innovative engineering and my own 401 for its solid timing (and the fact that it's mine and I built it!) but if you like it, why not?
  3. YNWOAN
    YNWOAN 100% Analogue
    No, they are total shit - that's why everyone who owns one loves it!
    Next question: The grass on the other side, is it really as green as they say?
    Seriously though, I would only consider a one if the motors (all three of them), the electronics and the main bearing were OK.
  4. sq225917
    I'm not sure they work with re-badged Denon 103's
  5. Jag Audio
    Jag Audio Trade: Jag Audio
    The Voyd reference is in my experience a superb turntable as long as it is all set up properly and fully functioning.
    I have a Voyd, not reference but the plus version that has a reference bearing/platter but normal split phase power supply (shoe box size). I am quite happy with my Voyd, different sounding to my PT Anniversary and the NA Mentor.
  6. jackal2513
    no, id put a cheap MM on it... just run it as a second 45rpm deck and for quickly checking through vinyl job lots
    always liked the plinth on the Voyd, I reckon it could be fun and a nice addition to the living room
  7. sq225917
    Good call, that's its true calling.
  8. stevec67
    stevec67 pfm Member
    Great idea, next up, I buy a Bugatti Veyron for the supermarket run and a 4x4 Hummer for popping down the paper shop. It could be fun and I like the way they look. In addition, I sometimes have to bump over the kerb to get to the paper shop parking spces, especially if someone else has parked carelessly.:confused:
  9. i_should_coco
    i_should_coco I am weasel
    I agree. It's shit. ;) Don't buy one Jackal.
  10. deserter
    deserter pfm Member
    Just stick with your resonant sand filled arm attached to a golf ball sitting in a bowl of gunk, with a heavy wobbly platter driven more or less firmly by a possibly or maybe not well knotted piece of fishing line, all sitting on some more sports accessories. forget looking at properly engineered decks, they dont work. Especially with non-cheapskate cartridges.
    You know it makes sense.
  11. zener
    zener fluff
    My Friend Les was involved at some point in its design , its rubbish , leave it some fool to buy.
