simonpyeman
Do you mean, whether the passive is before or after the long run?
Isn't this over-generalising though? Surely it depends on the gauge of the wire and the loudspeaker's impedance curve?Long interconnects and short speaker cable is the right way yes.
IME the longer the interconnect the more HF rolloff there is and the poorer the SNR becomes (for single-ended runs at least). I did a crude test to confirm this by recording the line output of my Yamaha integrated into an ADC using 1m and 5m runs of Van Damme XKE. I'd like to do the same test with my speaker cables but the measurement would need to be performed in the acoustical domain using a mic to detect FR changes, which is obviously going to be less sensitive/reliable than the basic electrical measurements I did on the interconnects.
Yep, much to the annoyance of uni students I’ve had working with me, and some musicians who think all live sound technicians should work to a textbook standards, I’ve ran single ended devices (electro-acoustic acoustic guitars/keyboards etc) straight down a 50 meter multicore to the desk via adapters because it sounds quieter, more dynamic and just all round better than it does through a w@nky DI box, for years without a single issue. I carry DI boxes “just in case”, but for me, it’s like having a fire extinguisher, ie, they will mostly never be used... and a live stage is a much more electrically noisy environment than any normal domestic room.No it's always the best way. If you are getting roll off before 50+ KHz you are doing something badly wrong and decently screened coax should be as quiet as anyone could want. Differences of say 98dB S/N and 104dB S/N are purely academic... both are silent in practice.
Obviously if using say 6mm speaker cable then 5m or more runs are no problem anyway but it makes sense to have the bit prone to resistive losses etc (speaker cable), and those losses effecting damping factor and hence interacting with speaker impedance curve as short and thick as possible hence ideally power amp between speakers with shortest cable runs and then use long interconnects. With a 10K passive and 100pF/m coax then worst case roll off with 10m of coax is -3dB @ 63KHz. With a solid state active pre then in most cases you should be fine even with 20m of coax.
This is what I thought, but always like to ask in terms of hi-fi. I didn't opt for Van Damme this time, but got Sommer Albedo instead. I love the various Sommer cables I already use, both at home and on stage/recording. I have no doubt that something similarly specced in the hi-fi world would have cost hundreds...
You will get better results keeping the interconnect cables short and use long speaker cables.
This is getting as enlightening as the Citywire Economics Forum!
I'm on 8m Mark Grant balanced and 1.5m Supra Classic.
The difference will be much less if you are using balanced cables than if single-ended cables are being used.
FWIW I utterly disagree with everything said by GT here including the balanced/unbalanced bit.
I guess everyone's findings can vary Jez, but I was led to believe longer interconnects with shorter speaker cables was the way. Have you tried the balanced/unbalanced bit with the leads at 8+metres?
I stick by what I have said earlier as I have proven this 30+ years ago when I was running an ARC SP8 pre-amp driving a pair of Quicksilver mono valve amplifiers. The Quicksilver amps were mounted directly behind the speakers and only used a few centimetres of wire, probably no more than 30cm (12"). I also have done the same experiment with a pair of Mark Levinson 6A preamps driving a pair of Mark Levinson ML2 Monoblock amps, again with just a few centimetres of wire between the power amps and the speakers. The interconnect cables were very high quality (Siltech) coax screened cables and about 10 metres in length. Using the above configuration I noticed a loss of dynamic range and a sound that was "laid back" compared to how the system sounded previously when it was wired with short interconnects (1 metre long) and long speaker cables. At the time I mentioned this to "hifi_dave" who resides on here and is a very well established Hi-Fi dealer and has been in the industry since the 1970s and he confirmed the same. Not sure if hifi_dave contributes on here any more but if he does I am sure he will be along to comment soon.
A year or too after experiencing this I sold my ML6 preamps and bought a Mark Levinson 26S fully balanced preamp. I tried the same experiment again using 10 metre balanced cables and found they were an improvement over the SE cables over that length but I still preferred using short balanced interconnect cables and long speaker cables.
Obviously, this is my experience but there seems to be an overriding thing going on here, in that if some can't hear the difference, or think that technically it shouldn't, therefore it won't make a difference. We all hear things differently due to our hearing, especially as we age, our perception of sound and the level or quality of sound we are used to, and the Hi-Fi equipment we use all has a bearing on what we hear, or are able to hear. I have very sensitive hearing so I can probably hear things others cannot. I can certainly hear differences between electronic components (diodes, resistors, capacitors, power supplies etc) and this has been invaluable to me in producing my electronics over the last 25 years which have been reviewed around the world. Also previously to that, I spent a considerable amount of time restoring and upgrading vintage and modern Hi-Fi which has been well documented in various Hi-Fi magazines.
To sum up:
1. Long interconnects have a much larger negative influence on audio performance the longer the cables are. Any RCA to RCA cable over 3 metres in length I would recommend going balanced if that is an option.
2. Preamps, depending on their design, vary in performance in how they can drive power amps over long interconnect cable runs and some are better than others.
3. Interconnect cables have differing specs (R, L & C) which have more of an impact on performance due to the signal level (voltage and current) being much lower coming from a pre-amp output than that coming from a power amplifier.
4. Power amplifiers are designed to drive low impedance loads (1 ohm to 30 ohms) with higher voltage and currents, and due to speaker cables having much larger conductor surface areas, plus lower R, L and C and this has much less of an effect on the signal as it passes along the cable.
There are more I could list but I think you get the gist...
I'd go along with that.I stick by what I have said earlier as I have proven this 30+ years ago when I was running an ARC SP8 pre-amp driving a pair of Quicksilver mono valve amplifiers. The Quicksilver amps were mounted directly behind the speakers and only used a few centimetres of wire, probably no more than 30cm (12"). I also have done the same experiment with a pair of Mark Levinson 6A preamps driving a pair of Mark Levinson ML2 Monoblock amps, again with just a few centimetres of wire between the power amps and the speakers. The interconnect cables were very high quality (Siltech) coax screened cables and about 10 metres in length. Using the above configuration I noticed a loss of dynamic range and a sound that was "laid back" compared to how the system sounded previously when it was wired with short interconnects (1 metre long) and long speaker cables. At the time I mentioned this to "hifi_dave" who resides on here and is a very well established Hi-Fi dealer and has been in the industry since the 1970s and he confirmed the same. Not sure if hifi_dave contributes on here any more but if he does I am sure he will be along to comment soon.
To sum up:
