Vann Damme speaker cable
Discussion in 'audio' started by Rallye_punk, Sep 23, 2019.
  1. Rallye_punk
    Rallye_punk pfm Member
    Has anyone tried the Vann Damme 4mm blue? I am fed up of paying through the nose for speaker cable and I now need some very long runs so it would cost a fortune. My current cable is Naca 5 and it was about 35 a meter. The Vann Damme is about £4 a meter, copper, ok it may not be as good but it will do the job for what I need. Anyone else used it and what do you think ? Thanks.
  2. linnfomaniac83
    I’ve not used it in my domestic setups but it’s what I use I’m my (excellent sounding) PA system, it’s rugged stuff, and much, much more flexible than Naca 5... the reason I don’t use it at home? It’s blue, and my skirting boards are white.
  3. early
    early pfm Member
    Nothing wrong with Vann Damme cables , I would put money on you not noticing any difference .
    There are others too don't discount Mogami or Sommer .
  4. hifinutt
    hifinutt hifinutt
  5. ToTo Man
    ToTo Man the band not the dog
    I've used Van Damme Studio Blue 2.5mm for many years. I also use Van Damme XKE interconnects. I have no desire to upgrade.
    Hoopsontoast likes this.
  6. Rallye_punk
    It was the blue stuff I was looking at. To be honest it's copper so should be decent, the Nac a5 is excellent I will say, but just too pricey for the runs I need. I've tried chord in the past and found that to 'darken' the sound, the Nac a5 is my fav by a long shot, so hopefully the VD cable should be similar in nature/sound.
  7. linnfomaniac83
    Yep, the XKE is superb stuff and costs very little, I now use it exclusively for all my pro audio needs, utterly dependable stuff.
    misterdog and ToTo Man like this.
  8. ToTo Man
    How long a run do you need? 2.5mm is plenty thick for runs up to 5m, but if you need significantly longer runs than this then you might be better with 4mm. I ordered 10cm samples of every thickness so that I could examine them. The 6mm was like a hosepipe, I wouldn't want to use that without stripping back a considerable portion of the outer jacket to remove weight and thus potential strain on amplifier and loudspeaker binding posts! The outer jacket thickness is a bit OTT IMO and is a bugger to strip back without the appropriate tools, but it does make for a very durable cable. They also make a 'hifi' version that looks more like domestic speaker cable, but after witnessing the colour of the copper inside the clear jacket of Gale XL-315 speaker cable change from a fresh pinky colour to a dull brown colour due to exposure to UV light over the course of a couple of years, I have been put off buying any more cables with a transparent jacket.
  9. Naimlover
    Naimlover Member
    Is your current amplifier Naim? Van Damme Blue is not suitable for Naim amps, but their flat HiFi range is compatible apparently. I use 4mm VD blue with my Quad 306 to excellent effect, Naca5 for my Naim amps. Consider Witch Hat for their flexible speaker cables which are cheaper than Naca5 if you own Naim.
  10. zippy
    zippy pfm Member
    I used 6mm blue for a long time - excellent - I fairly recently changed to V.D. LCOFC which seems to give a slightly better sound - I'm not sure why you need blue specifically - maybe you should think about the LCOFC.
    chris@panteg and Rug Doc like this.
  11. MVV
    MVV pfm Member
    I use Van Damme tour black and first used it when I had Naim amps and like you needed long runs. I didn't hear any difference but rather liked that is was easier to run about.
  12. Rallye_punk
    Why is not suitable?
    What Naim amps do/did you run, taking cognisance of the above?
  13. Pinky
    Pinky In suspense, not compressed
    It's also worth considering Linn K20 which is effectively Naim NACA4 and can be had for around £6 metre. It's a heck of a lot more flexible than NAC A5.
  14. linnfomaniac83
    Forgot that stuff still existed, but yes, a sensible no BS speaker cable.
    Pinky likes this.
  15. PerF
    PerF Member
    I ran 7mtr pair VanDamme Concert ofc but changed successfully to 5mtr WH Phantom by re-designing room.
    I recall K20/A4 is smoother
    Same cable branded Talk & Exposure
  16. Rallye_punk
    Does anyone know why it's not recommened for Naim then? I have 2 x 135 mono amps...
  17. Naimlover
    Naimlover Member
    hifinutt likes this.
  18. hifinutt
    hifinutt hifinutt
    Now that is a very interesting article , i am pretty sure i used the van damme with my supernait 2 . perhaps i should not have done so
  19. Julf
    Julf Facts are our friends
    Because Naim left out the normal compensation network (the engineers amongst us would call it a bad design decision), and as a result the amps become unstable and oscillate unless provided with the right load inductance and capacitance.
  20. Paul_Riordan
    Paul_Riordan pfm Member
    I have it installed with some secondary systems in the house - Auralic Aries Minis with Project power amps and it seems pretty neutral - not used for critical listening but seems pretty good and works well installed behind walls / through ceilings etc as it is fairly flexible.
